    First layer gets ignored
    • Sitnetz
      Sitnetz last edited by
      Hi guys,
      I am new in the duet community, just converted my first printer to a duet(ender 3).
      Please excuse my broken English...
      Got the printer to home as intended, so when I "home all" the nozzle is a sheet of paper away from the bed. But if I start a print the nozzle is at 0.2mm but should be at 0mm. I am a bit scared to set a offset to the nozzle because I think it would crash into the bed while homing. I am using an end stop switch at the z-axis. So no probe installed.
      What do I have to do to get the nozzle to 0mm at the start of a print?
      • DocTrucker
        DocTrucker last edited by
        That's working correctly.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
        • DocTrucker
          It the extruder was at z=0 it would most likely drag the nozzle over the print surface.
          In addition the first layer height would be 0, which would mean there is nothing to extrude.
          • Sitnetz
            That means that I have to set my nozzle to bump slightly against the bed?(does not make sense to me)
            Because when I home the hight is correct and when I start a print the nozzle is to high
            • DocTrucker
              When you start the print the nozzle height should be at the height of the first layer which is typically about 0.2-0.3mm depending on your slicer settings.
              The print should not start with the nozzle touching the bed.
              Your probe offset should be set so that when z=0 the nozzle just touches the bed.
