    Solved Duet2 Wifi - Cannot connect to WIFI
    • tonyp
      tonyp last edited by
      I have followed the docs precisely and also forum posts non can seem to help. I'm trying to setup the Duet2 Wifi and it is not accepting my wifi network. I'ts about 1.5M away (Airport Time Capsule on 2.4Ghz).
      When I login via screen no problem, it loops horrible on both ubuntu and mac with crazy tabbing. But anyway we connect and then get:
      WiFi reported error: no known networks found
      WiFi module is idle
      After that I run M115 Command and we see:
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
      Great so far so good. Next I try and setup the WIFI noting this is just basic pw to get Duet to work:
      M587 S"OPartridge" P"welcome2017"
      We then get:
      WiFi module is idle
      M587: Failed to add SSID to remembered list
      ok
      Error retrieving WiFi status message: bad reply format version
      WiFi module is idle
      It's not a networt distance issue as I've also tried putting it ontop of the wifi box.
      Just in case.. I try to connect anyway:
      M552 S1
      Nothing still loads of:
      e
      WiFi module is idle
      Anyone have any suggestions here? I was hoping I could just configure via JSON or similar.
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s4
        How are you sending the commands? Via terminal?
        One way to circumvent any weirdness from the terminal garbling your commands is to use a macro which contains the command to add the network, then sending acommand via the terminal to run that macro.
        Alternatively you can edit the config.g on your PC to include the network add command. Boot up the board, it runs config.g automatically, the network gets added, then you can remove that line from the config.g.
        Also, can you confirm the version of your WIFI server firmware by sending M122. The results of the wifi portion are towards the end.
        • tonyp
          Yep via Terminal. I've done the build online as a try and loaded it to the SD Card But then I get:
          WiFi module is idle
          ok
          The M122 Command reports:
          WiFi firmware version 1.21
          WiFi MAC address cc:50:e3:0d:2b:53
          WiFi Vcc 3.38, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 19968
          ok
          • tonyp
            Forgive me I am a complete Idiot. I had setup the wrong Wifi Name on the router when I changed it. Sorry guys and thanks!
              dc42 administrators @tonyp last edited by
              No problem, I'm glad you got it working! Have fun.
