SOLVED Corexy start printing crashes bed
Hello
I have a core XY without z-probe and an duet2 ethernet. I´ve changed from repetier radds 1.5
If i start a print everthing works fine untill G1 Z15 F6000 in the startcode (cura), then chrashes the bed in the optical endstop.
Homing works fine.
Has anyone an idea what the problem is?Sorry for my bad english...............
My files:
config.g
0_1551898375232_config (1).g
homeall.g
0_1551898470684_homeall.g
Startcode cura
G28 ;Home
G1 Z15.0 F6000 ;Move the platform down 15mm
;Prime the extruder
G92 E0
G1 F200 E3
G92 E0
your homeall has
G92 Z50this tells the printer the current position is at height 50
then
G1 Z15.0
move the bed up by 35mm.
Thanks i will try.
I have ajust the endstop and change the homeall file to z0, the bed is heating.
I`ll give you feedback
Now the printer is printing. It was the solution!
Thank you so much.
