    Duet Board Wifi connection to Enterprise network ieee 802.1x
    • seeger
      seeger last edited by
      how can i connect the Duet Board to our Enterprise Network?
      I need to set 1. the acces point 2. the username an 3. the password. But in the configuration tool there is no possibility to set an username.
      • Danal
        Danal last edited by Danal
        Enterprise authentication is an entirely different protocol that WPA2. Duet does not, and will probably never, support it. (I am not a developer for Duet... I am an enterprise authentication expert, and would recommend the Duet developers not touch it with a 10 meter pole).
        Instead, you can easily set up a router that authenticates to your Enterprise network (perhaps on WiFi, perhaps on Ether) and establishes a WPA2 wireless network for the printer to join. You can lock that WPA2 network down to a single MAC, etc, etc.
        Quite a few commercially available routers can be configured to do this with their default firmware, or you could run WRT (open source firmware) on any number of off-the-shelf router hardware platforms. There is a huge list on their site. https://openwrt.org/
        Personally, I'd go the WRT path... it is designed to do things like this and there are examples all over their site.
