    Duet Board2 Wifi connection to Enterprise network ieee 802.1x
    Duet Web Control
    • seeger
      seeger last edited by
      how can i connect the Duet Board2 wifi to our Enterprise Network?
      I need to set 1. the acces point 2. the username and 3. the password. But in the configuration tool there is no possibility to set an username.
      • snoozer
        snoozer last edited by snoozer
        looks to me that 802.1x is not implemented in the RRFirmware according to gcode documentation.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
        and here:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
        Rgds
        Jan
        Regards Jan
        My Printers:
        #1 Prusa i3 MK3 kit all stock (Retired)
        #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
        My Experiments:
        https://www.thingiverse.com/snoozer17/designs
        • seeger
          It seems so. Is there a way to implement it in the RRFirmware?
          • snoozer
            I guess there would probably be, but I would have doubts that it would be done. Probably more a WiFi Board thing anyway. Seems a rather isolated issue by the looks of it, I would consider a wired board and have that hooked up to a switch or if it has to be WiFi use a stand alone WiFi client device capable of 802.1x and hook up your ethernet to that.
            Jan P.
            Regards Jan
            My Printers:
            My Experiments:
              This may be a temporary work around: https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
              Setting up the duet to work as an access point allows it to create it's own wireless network which you can connect to from your control device.
