    TWO Y SYNC HELP
    Order discussion
    • q1900dc
      q1900dc last edited by
      I would like to ask for help for me hard to understand gcode!
      I want two y axis 2 controller 2 engine but move in sync and switch to an estop ending!
      Y AXIS = Y DRIVER
      Y2 AXIS = E1 DRIVER
      SINGLE ESTOP = Y STOP IN
      can anyone write files?
      FILE CONFIG
      • deckingman
        deckingman @q1900dc last edited by
        @q1900dc said in TWO Y SYNC HELP:
        Y AXIS = Y DRIVER
        Y2 AXIS = E1 DRIVER
        FILE CONFIG
        Well without knowing which Duet you have and what sort of printer it is, one can only hazard a guess. All you need to do is map the two drivers to the Y axis. Assuming it's a Duet Ethernet or Wifi, then the drives numbers are as follows:
        X is drive 0,
        Y is drive 1,
        Z is drive 2,
        E0 is drive 3
        and E1 is drive 4,
        So to use drive E1 as well as the normal Y driver, then you'd use something like this in your config.fg file.
        M584 X0 Y1:4 Z2 E3
        That's all you need do. If you only have a single end stop, then you don't need do anything differently to configure it.
        q1900dc 1 Reply Last reply Reply Quote 0
        • q1900dc
          q1900dc @deckingman last edited by q1900dc
          @deckingman said in TWO Y SYNC HELP:
          E1
          helló!
          e1 is not moving!
          config
          ; generated by RepRapFirmware Configuration Tool v2 on Thu Mar 07 2019 22:44:24 GMT+0100 (közép-európai téli idő)
          M550 P"DUET3D" ; Set machine name
          M551 P"" ; Set password
          M552 S1 ; Enable network
          M586 P0 S1 ; Enable HTTP
          M586 P1 S1 ; Enable FTP
          M586 P2 S0 ; Disable Telnet
          M584 X0 Y1:4 Z2 E3
          M92 X80.00 Y80.00 Z800.00 E145.75 ; Set steps per mm
          M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z180.00 E300.00 ; Set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z20.00 E10000.00 ; Set accelerations (mm/s^2)
          M906 X1000.00 Y1000.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X300 Y300 Z300 S0 ; Set axis maxima
          M574 X1 Y1 Z1 S1 ; Set active high endstops
          M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
          M557 X15:200 Y15:200 S20 ; Define mesh grid
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          M563 P0 D0 H1 ; Define tool 0
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          • Catalin_RO
            Catalin_RO last edited by Catalin_RO
            Maybe missing M569 P4 Sx (replace x with whatever you need for correct rotation sense)?
            • q1900dc
              Why is there no double axis option?
              An expensive hardware is the duet3d and such a cumbersome setting I don't understand is not everyone with programming skills I could simplify setting here ...
              https://configurator.reprapfirmware.org/Motors
