    DWC always showing layer X/775
    Duet Web Control
    • Surgikill
      Surgikill last edited by
      So my DWC always shows a max of 775 layers. I'm not sure if this is a known issue with DWC, or maybe it's a browser issue or something with my gcode. Any ideas?
      Phaedrux dc42 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Surgikill last edited by
        @surgikill firmware and DWC versions?
          dc42 administrators @Surgikill last edited by
          @surgikill said in DWC always showing layer X/775:
          Do you mean that it shows the print as having 775 layers? If so, that's because you have a G1 Z command to move the print head to a high print height, in your slicer ending script. To fix it, either add a comment starting with ";E" to that line, or use an end.g file and put the command in that file.
