Dual extruder, 1 hotend
Hey guys,
So, I take it that Duet will most likely work fine with the Prometheus system, minus some g-code magic? I'm itching to place the order :).
Thanks!
Yes, the Duet supports switching hot ends, which is what you get with the Prometheus system.
I am still getting what appear to be uncommanded tool changes happening despite removing any T commands from my gcode, which is making printing with one material (using my second extruder) difficult to say the least.
For compatibility with slicers that don't handle tool switching properly, an M109 command with a T parameter will cause a switch to that tool in recent versions of RRF. So check your gcode for M109 commands.
