    G32 not working properly
    • Will Baxterundefined
      Will Baxter
      when i auto level using the G32 command when it is making the adjustments at the end i can see the bed being adjusted out of level . i run G32 3 times the bed is never level . any thoughts
      • aidarundefined
        aidar
        Have you seen this: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors ?
          Will Baxter
          Yes everything works except the adjustment at the end of the probing
          • aidarundefined
            aidar
            From link above :
            "You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command."
            Are you sure that ALL conditions mentioned above are met? Specially the one in bold?
