Tutorial - running Duet Wifi 2 in Access Point Mode ?
@sputnikoc3d any usb terminal emulator program should work. Bear in mind the capitalization thing I posted above.
The paneldue has a on screen keyboard that you can enter commands on and an interface to execute macro files that are already on the SD card.
@sputnikoc3d said in Tutorial - running Duet Wifi 2 in Access Point Mode ?:
Off to the elecreinics store to find a long enough USB cable now that will reach from Intel NUC to Printer. Pronterface ok here for this YAT is just not my cup of tea - at all.
Just FYI I use a program called Docklight Scripting when I need to send commands and respond to replies from things like the Duet USB port.
I have gotten so much use out of it over the years using it in all sorts of situations.
Bear in mind that Pronterface forces all the characters you send to upper case, which is awkward for entering passwords in particular. That's why we suggest YAT for this purpose.
