    Solved Noise from motors
    • Viald
      Viald last edited by
      Hello.
      I know that this topic has already been discussed many times on this forum. But my case is a bit different.
      I use the duet3D Wifi on my delta printer since few months and compare to the previous smoothie controller, for sure the motors did no noise.
      But since yesterday, all the 3 motors have strange continuous noise after the first mouvement.
      No setting has been modified, I have just recalibrated my aluminium frame.
      Recalibrate my frame did not solve my first issue, now I have 2 issues, so bad 😞
      Where could it come from ?
      Thanks
      K250VS Delta Printer / Duet 2 WiFi / Firmware: 2.05.1 / Duet WiFi Server Version: 1.23 / Duet Web Control 2.0.7
      • nhof
        nhof last edited by
        When you say 'recalibrated aluminum frame' what do you mean?
        If you changed the way parts are connected or tightened them, the frame could be resonating differently than before which could cause more audible noise.
        Viald 1 Reply Last reply Reply Quote 0
        • Viald
          May be it could be the reason even if I have vibration damper between the frame and the steppers.
          But for sure the noise comes from the steppers.
          • Veti
            Veti last edited by
            are you using 12v or 24v? tmc stepper motors require above 18v for quiter operation.
              Has your VIN voltage changed?
              • Viald
                Still at 24.1 V according duet3d dashboard
                • Viald
                  Viald @nhof last edited by
                  @nhof said in Noise from motors:
                  You're fully right ! It was a resonating issue. I disassembled and assembled again all parts of the 3D printer, and the silence is back 🙂
                  Thank you.
