    Solved BLTouch logic conversion
    • Harley3D
      Harley3D last edited by
      I think i saw somewhere that on the newer Duet3D WiFi 1.04 boards you don't need to cut the copper line logic conversion on the BLTouch Smart. Is there any truth to this?
        Yes it should work fine without the trace cut. If it doesn't seem to behave properly, cut the trace.
          For all Duet 2 WiFi/Ethernet boards prior to version 1.04
          If you have the older BLTouch, also connect the 240 ohm resistor between Probe GND and Probe IN. On the newer BLTouch, cut the PCB trace on the BLTouch to reduce the output to 3.3V as described in the BLTouch instructions.
          The Z probe input on the Duet 2 Maestro and Duet 2 WiFi/Ethernet rev 1.04 and later is 30V tolerant, so it doesn't matter whether you reduce the output of the BLTouch to 3.3V or leave it at 5V.
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
          • tenjin
            tenjin last edited by
            i didnt cut any traces,. and works fine
            • Harley3D
              Thanks, Worry over!
