Unable to run Gcodes from Estlcam in Web control
- In your M92 command you specified 200 steps/mm @ x16 microstepping. Is that correct?
- If you send M92 without parameters, does it report that the Z steps/mm is 200?
- If you use the jog buttons to jog Z up 5mm, does it rise the correct amount?
@dc42 said in Unable to run Gcodes from Estlcam in Web control:
Changed it to 400 steps/mm (T8 screw)
Steps/mm: X: 100.000, Y: 100.000, Z: 400.000, U: 100.000, V: 100.000, E: 420.000:420.000
Yes, I measured the correct amount with my digital caliper. The difference is only 0,01mm.
@3DRikat Please try to use a work piece coordinate system. If you generated G-code with a Z-axis zero position at work piece upper surface, Z-axis will move outside machine limits when the tool dives into the material. Same can happen if your cad design touches X- or Y Axis zero in Estlcam and you add cutter radius compensation. Toolpath will be outside machine limits.
I used following G-code: G10 L2 P2 X5 Y5 Z25 to select 2nd coordinate system and activated it with G55.
@radiomodell I tryed it but it was just like before. After the outer square is done the Z axis rises and I have to stop it. There's the error message "outside machine limits".
I really don't know why the Z axis rises so high.
@3drikat said in Unable to run Gcodes from Estlcam in Web control:
Neither do I!
What happens if you send the commands in that file one at a time from the command line?
I got it working now
There was a endstop set for the z axis
M574 X1 S1 C0
M574 Y1 S1 C1
M574 Z2 S1 C2
M574 U1 S1 C4
M574 V1 S1 C3So I changed it to
M574 X1 S1 C0
M574 Y1 S1 C1
M574 Z0
M574 U1 S1 C4
M574 V1 S1 C3and now it's working. Thank you all for your help.
