    RepRap Firmware make Backup
    558
    • bfpa40
      bfpa40 last edited by
      Is there a way to make a backup of all the system files (config.g, homeall.g, homex.g etc...) files that Reprap uses?
        Yes. Go to System Editor in DWC and click the check box next to the Filename heading. This selects all files. Then un-check any directories. Then right click on any filename and select "Download as zip".
        • bfpa40
          Ive tried to connect to it via ssh and i see its active but whats the username and password SSH is expecting?
            Duet doesn't support SSH. It does support (insecure) Telnet if you enable it using M586, but that won't help you make a backup.
            • bfpa40
              Gotcha, i used your earlier instructions and got what i needed. Thank You again!
                It's also possible to enable FTP using M586 and use that to download files; however we've had some reports of FTP being unreliable. I'm not sure whether that is for uploading, downloading, or both. It's on my list to fix.
                • bfpa40
                  Yea i just tried it doesnt respond they way im used to ftp responding also requests a "name" and "password'
                  snoozer 1 Reply Last reply Reply Quote 0
                  • snoozer
                    snoozer @bfpa40 last edited by snoozer
                    @bfpa40
                    I have used admin as username and the password is the same as for DWC access, for my backup I do it from a Linux system and use wget.
                    wget --ftp-user=admin --ftp-password=PASS -r ftp://IPADDRESS/sys/
                    Did it for me.
                    Jan
                    Regards Jan
                    My Printers:
                    #1 Prusa i3 MK3 kit all stock (Retired)
                    #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
                    My Experiments:
                    https://www.thingiverse.com/snoozer17/designs
                    bfpa40 1 Reply Last reply Reply Quote 0
                    • bfpa40
                      bfpa40 @snoozer last edited by
                      @snoozer I use Ubuntu 18.10 and i just got in used ftp: IPADDRESS in files, other locations and it popped right up. Pretty awesome!
