    Duet3d Wifi constant disconnects
    1
    126
    • cybin
      cybin last edited by cybin
      [EDIT]
      I've found the update of WiFi server 1.22. Didn't recognized at first that there are different parts of the firmware. So, I thought it was up-to-date. After installing this update it seems to be reliable now. Though, I will keep close eye on the network and will respond to this post if it still disconnect.
      I'm sorry to raise your attention, though I shouldn't but working the Trouble Shooting Guid completely, first.
      [/EDIT]
      Hi!
      I've setup Duet for my WiFi, but it is constantly disconnecting. What ever I do:
      • different channels
      • b/g/n
      it just connects to loose connection a few moments ago. How do I solve this problem? Research for the ESP-12S shows that this seems to be a common problem, but there is no overall solution, afaik.
      This is the only device with which I've a connection problem, so it's most certainly not my router (Netgear X6 R8000).
      I'm kind of lost and appreciate any help.
      Thanks in advance,
      cybin
