    Standby -> Active, temp lost
    Duet Web Control
    • fotomasundefined
      fotomas
      After a print my printer stands pre-heated (at 100C) in standby. When I start slicing my next print I click the heater in DWC to get to active and prepare for printing temp.
      But going from standby to active resets all the temps to zero.
      I'm a doing something wrong, or is it not ment to be used like this?
      Or maybe it is a bug...
      Duet Web Control 2.0.0-RC6
        Please try reverting to DWC 1.22/.x and see if the problem remains. There is a link in DWC 2 to do run the old version of DWC, in the User Interface page.
        • fotomasundefined
          fotomas
          Tested old DWC too /reprap.htm an the behaviour is the same.
          But I think I understand the behavior now, the heater state is cycled Active->Standby->Off->Active-> ... and so on.
          So to go from standby ro active, manually, must go via off.
          So it seems to by design. But a better solution would be preferable, one where any of the states can be selected directly.
