Compile error [2.03beta]
I'm trying to compile new version firmware (2.03beta03 for Duet 2). I red a buildinstructions.md and I have necessary tools and versions, but I get error (see error.log).
I also tried to compile version v2-dev and this version compile without any errors.
Any ideas?
Do you need more information?
0_1552981893004_error.txt -
Looks like the version of the RRFLibraries project you downloaded is too old for the version of the RepRapFirmware project.
You're right. I've changed RRFLibraries branch to dev.
Thanks!But it means that BuiltInstructions.md has a mistake.
There should be RRFLibraries dev instead of main.
Thanks for pointing this out, I have corrected it. The latest commits also use the dev branch of CoreNG.
