    g-Code hints in g-code console
    Duet Web Control wishlist
    • c310
      c310 last edited by
      I suggest to add g-Code hints in g-code console, similar to hints in MSOffice
      Let say I start typing M106 command. With M10 typed it can show options
      • M104: Set Extruder Temperature
      • M105: Get Extruder Temperature
      • M106: Fan On
      Once i select or type M106 it will show possible options and provide link to our documentation site...
      samples are below. 🙂
      Parameters
      Pnnn Fan number (optional, defaults to 0)
      Snnn Fan speed (0 to 255 or 0.0 to 1.0))
      Extra Parameters
      Innn Invert PWM (I1), disable fan (I-1), or normal mode (I0, default)
      Fnnn Fan PWM frequency
      Lnnn Set the minimum fan speed (0 to 255 or 0.0 to 1.0) when a non-zero fan speed is requested.
      Xnnn Set the maximum fan speed (0 to 255 or 0.0 to 1.0) when a non-zero fan speed is requested. (supported in RRF >= 2.02)
      Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill. Default is B0.1.
      Hnn:nn:nn... Enable thermostatic mode and select heaters monitored. H-1 disables thermostatic mode.
      Rnnn Restore fan speed to the value it has when the print was paused (R1) or the last time the fan speed was set and no P parameter was provided (R2).
      Tnnn or Tnn:nn Set thermostatic mode trigger temperature, to temperature control range
      C"name" Set custom name for this fan (supported in RRF >= 2.01)
      Ann Logical pin number that this fan is connected to (supported in RRF >= 2.02)
        Nice idea!
        • CCS86
          CCS86 last edited by
          I was thinking something similar, in being able to type in plain text and see suggested gcodes that have matching keywords. These two ideas together would be so helpful.
