    Endstop Maestro
    348
    • B3rserK
      B3rserK last edited by
      Probably a stupid question, but being a rookie and be afraid to fry everything , I ask for an help.
      I tried to look for an answer, but without success (or at least not a sure answer).
      With this type of endstop (from a cr10), is my hypothesis correct?
      Maestro - Endstop PCB
      1. Y stop - V pin
      2. 3.3v - S pin
      3. GND - no pin
        and use "normally closed" setup
        That board appears to have spaces for two resistors, a capacitor and an LED. But in the photo, it appears that they are not fitted. Is that correct?
        If that's the case, pick whatever two pins of the connector correspond to the NC contacts of the switch, and connect those to the outer two pins of the 3-pin connector on the Duet. Do not connect the 3.3V (centre) pin on the Maestro endstop connector to anything, use the STOP and GND pins on the Maestro.
        • Veti
          Veti last edited by
          V is Voltage
          S is Signal
          G is ground
          you can find out if its no or nc by connecting it and issuing M119
          • B3rserK
            First of all, dc and veti, thank you for your interest for my stupid question ☺
            Board appears exactly like the photo, there are spaces but not fitted.
            Weel i will try in that mode, it's correct?
            Maestro Pins
            1. STOP -
            2. 3.3v - No pins
            3. GND -
            Connect 1-3 pins to "random" pins on pcb and try command M119 to understand if is NO or NC
              dc42 administrators @B3rserK last edited by
              @b3rserk said in Endstop Maestro:
              Yes.
              B3rserK 1 Reply Last reply Reply Quote 1
              • B3rserK
                B3rserK @dc42 last edited by
                @dc42 Thank you 🙂 i'll try
                  My guess is S and G.
                  • B3rserK
                    Tryed!
                    Maestro - Endstop pcb
                    1 Stop - S
                    2 3.3 No pins
                    3 GND - V
                    launching M119 appears "not stopped"
                    clicking on endstop " at max stop"
