    UNSOLVED Stealthchop2 to Spreadcycle switch
    Firmware wishlist
    844
    • Veti
      Veti last edited by
      I run stealthchop at quite high speeds. about 80mm/s
      When i switched to 0.9degrees steppers the setting was lowered.
      The problem is that when the driver switch between stealthchop and spreadcycle at high speed this causes a loud noise and in my case layer shifts. After i increased the limit so that it would not switch, i had no layer shifts.
      Currently the switch is done via setting the TPWMTHRS parameter and the switch is done by the trinamic driver.
      Would it be possible to do the switch based on the requested speed.
      So i.e Print move at 60mm/s -> Ok remain in stealthchop
      Travel move at 150mm/s -> Switch to Spreadcycle, then move.
        Do you mean switch to spreadCycle at the start of a move that is planned to exceed the threshold speed, instead of switching when the threshold speed is exceeded?
        It might be possible, but it would require move-by-move reprogramming of the drivers via the UART. There would be some latency between the start of the move and the command reaching all the drivers. It will be easier to do on Duet 3 because the drivers will use the faster SPI instead of UART for reprogramming.
        • Veti
          Veti last edited by
          @dc42 said in Stealthchop2 to Spreadcycle switch:
          yes with some intelligent logic. i.e if its already in the required mode then dont issue the command.
          do you know that the latency would be?
            dc42 administrators @Veti last edited by dc42
            Off the top of my head I think the latency should not exceed 10 milliseconds. I will need to check with Trinamic what happens if you reduce TPWMTHRS when the motor is in stealthchop mode and already moving above that speed.
            • Veti
              Veti last edited by
              from the TMC documentation: https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2130_datasheet.pdf
              A jerk occurs when switching at higher velocities, because the back-EMF of the motor (which rises
              with the velocity) causes a phase shift of up to 90° between motor voltage and motor current. So
              when switching at higher velocities between voltage PWM and current PWM mode, this jerk will occur
              with increased intensity. A high jerk may even produce a temporary overcurrent condition (depending
              on the motor coil resistance). At low velocities (e.g. 1 to a few 10 RPM), it can be completely
              neglected for most motors
              • CCS86
                CCS86 last edited by
                This idea really interests me, because I haven't found stealthchop very useful, due to the switch to spreadcycle. Even though it hasn't been shifting layers, it makes a really loud clunk when switching.
                Even if I set the V parameter to keep all my 30-50 mm/s print moves in stealthchop, it clunks when making 180mm/s travel moves.
                My setup: Ultimaker Original cartesian printer. Running these steppers on X and Y, on a Maestro at 24v on RRF3.01RC11:
                Is there some additional tuning I can do to get these steppers working more seamlessly in stealthchop?
                • skezo
                  skezo last edited by
                  @CCS86 did you manage to find a solution for this? I experience the same thing with my maestro. For now I have disabled stealthchop2 but would love to use it as it makes my printer very quite.
                  CCS86 1 Reply Last reply Reply Quote 0
                  • CCS86
                    CCS86 @skezo last edited by
                    @skezo said in Stealthchop2 to Spreadcycle switch:
                    I haven't.
                    Was hoping to get some insight from the devs here, but it's not high on the priorities I guess.
