    Change Homing Order
    Firmware installation
    • Gummix
      Gummix last edited by
      I have a little problem with the homing of the X and Y axes.
      I have to drive first Y and then X to the end stop.
      At the moment it drives both axles at the same time and so it doesn't work with my setup.
      Thanks
      • SupraGuy
        SupraGuy last edited by
        When does it do this?
        The G code file homeall.g gives the instructions to the printer in order to home all of the axes, X, Y and Z.
        homex.g homes the X axis only. homey.g homes the Y axis only. homez.g homes the Z axis only.
        At the end of print jobs, you will often see something like
        G28 X Y
        G28 is the home command, and the X and Y are the flags to tell it to only home those axes. By convention we tend to list them in alphabetical order (X, then Y, then Z) when we do that. It will then call the appropriate gcode file to home those axes.
        It sounds though like you're using homeall.g, since you mention that it does X and Y at the same time.
        My homeall.g file looks like this:
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool on Thu Aug 30 2018 14:11:29 GMT-0600 (Mountain Daylight Time)
        G91                   ; relative positioning
        G1 Z5 F6000 S2        ; lift Z relative to current position
        G1 S1 X245 Y280 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 X-5 Y-5 F6000      ; go back a few mm
        G1 S1 X225 Y280 F300  ; move slowly to X and Y axis endstops once more (second pass)
        G90                   ; absolute positioning
        In order to change it so that it homes Y first, then homes X afterwards:
        ; homeall.g
        G1 S1 Y280 F3000      ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y-5 F6000          ; go back a few mm
        G1 S1 Y280 F300       ; move slowly to Y axis endstop once more (second pass)
        G1 S1 X245 F3000      ; move quickly to X axis endstop and stop there (first pass)
        G1 X-5 F6000          ; go back a few mm
        G1 S1 X225 F300       ; move slowly to X axis endstop once more (second pass)
        Lead screw driven printer, powered by Duet Wifi
        MPCNC powered by Duet Wifi
        • Gummix
          thanks i will give it a try.
