    Cant home z in laser mode
    • Zandr
      Zandr last edited by
      Hi, I am having an issue in laser mode where when i try to home my z it will move all the way up but ignore the end stop. i dont have this problem if i switch to FFF mode.
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool on Mon Mar 12 2018 16:19:25 GMT+0000 (GMT Standard Time)
      G91 ; relative positioning
      G1 S1 Z94 F1500 ; move quickly to Z axis endstop and stop there (first pass)
      G1 Z-3 F2400 ; go back a few mm
      G1 S1 Z94 F300 ; move slowly to Z axis endstop once more (second pass)
      G90 ; absolute positioning
      • A Former User
        In laser mode S sets the laser power, you need to use H instead to control the limit switch behaviour (can use H in FFF mode as well)
        Zandr 1 Reply Last reply Reply Quote 1
        • Zandr
          Thank you i will give this a shot i knew it had to be simple 🙂
          • Zandr
            Zandr @Guest last edited by
            @bearer thank you all working 🙂
