    [SOLVED] Paneldue shows connecting…
    • celulari
      celulari last edited by
      Hello Everybody!
      Sorry to bother, but until yesterday my paneldue was working flawlessly, but today constantly shows "connecting" on the corner. Already checked the baudrate, but Is ok.
      Can't access sd contents vía the LCD or read coordinates of the axis, but i can input g-codes from the console like M80 to turn on the dedicated 24v PSU.
      I don't know what else to do.
      Oh, btw, i'm using a duet WiFi and updated all the firmware.
      Thanks
        Most likely there is a bad crimp connection in the cable. If sending commands works, then it must be in the wire that feeds the Din pin of the PanelDue.
        • celulari
          @dc42:
          Thanks for the response. Was one of the first things i've checked once i decided yo get my hands dirty.
          Dissassembled the printed case for the paneldue and removed the green board, then attached allí again and it was working! I think the back board came loose due to vibrations…
            I just remembered, there was a bug in the GNU C library that caused older versions of PanelDue firmware to freeze sometimes when used with later versions of RRF. If it happened at all, it was duringRRF start-up. Pressing the Reset button on PanelDue resolved it. If you are using an old version of PanelDue firmware, then that might have been the problem.
