    Endstop optical configuration
    • Peppino12
      Peppino12 last edited by
      Hello everyone, is going to receive a duet 2 wifi 1.04, I can install classic optical stops on this board, as they are configured on the online configurator, on a board with marlin I configured as electronic, normally gnd but I can't find the correct parameter on the configurator online of the duet, I'm new with this card and before making mistakes I ask you.
      thank you
      • aidar
        aidar last edited by
        What you mean by classic optical stops? If they are common optical endstops with 3 wires (V, S and G), then they usually work fine with duet. You have to connect them to endstop connectors the way that V goes to 3,3v, G goes to ground and S goes to signal. In config they are configured just as usual endstops with active high output, so with S1 parameter. Look at https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams and https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration .
        • Peppino12
          Exactly, the limit switches with three wires are all clear for now thanks, I hope I don't bother too much with too many goat questions :)) but I'm new with this board, I'm setting up a kossel-like delta with a 340mm flat and a height with linear guides from 900mm, for now I'm documenting while I wait for the card to arrive
          • aidar
            You welcome. Duet wiki will answer most, if not all of your questions.
            • Peppino12
              Peppino12 last edited by Peppino12
              Thanks for the availability, another question if possible, coming from marlin for me is all new and I am afraid of doing damage, so it is possible to configure https://www.thingiverse.com/thing:3212906 instead that bl touch and similar
              thank you
                Phaedrux Moderator @Peppino12 last edited by
                @peppino12 I think that probe could work. You would need to use probe type P4 or P5 depending on how you connected it.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
