Can you set external triggers to toggle gcode?
  • So I have my printers lighting setup on Fan channel 1 (0 being primary fan)
    Now I would like to set a momentary button to turn the leds on or off. Or even if possible several stages of brightness.
    In c it would be something as simple as changing the state of a boolean light!=light;
    But is it possible to make a trigger do a if statement? If fan1==0 ; fan1=1;... type thing? Or toggle a boolean?
    Can complex scripts be stored in the .g config or trigger.g files?
  • Moderator
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
    You may be able to work out something with this.
    The conditional scripting you describe isn't currently possible, but is being worked on.
  • Yeah I've been reading that already. That's fine for setting a state with a single button... Like an end atop or emergency stop. But I would like the ability to cycle through two states or more.
    Is there any kind of expression system that can be used?
  • I have a dynamic button on my Duet, for one example, when a print starts, it is configured for trigger6
    trigger6 contains a command for pause
    pause contains a command to reconfigure the button for trigger7
    trigger7 contains a command for resume
    resume contains a command to reconfigure the button for trigger6
    etc etc
    should be easy to do it for LED stuff
  • Actually that sounds reasonable.... Thanks 🙂
  • Ok having a problem...
    At the end of my config file I have
    M106 P1 S1 ;Turns lights full bright
    M581 T2 E3 S0 ;Light switch
    trigger2.g
    M106 P1 S0.66 ;Turns lights 1/3down
    M581 T3 E3 S0 ;preps next trigger
    trigger3.g
    M106 P1 S0.33 ;Turns lights 2/3down
    M581 T4 E3 S0 ;preps next trigger
    trigger4.g
    M106 P1 S0.0 ;Turns lights off
    M581 T5 E3 S0 ;preps next trigger
    trigger5.g
    M106 P1 S1 ;Turns lights Full on
    M581 T2 E3 S0 ;preps next trigger
    The lights will cycle down once and back to full bright as the button is pressed. But trigger5, the prep next trigger doesnt seem to work.
    So i press the button from fresh restart, turns down 1/3 press again turns down another 1/3 press once more turns off, press again and turns on full bright, but pressing again does nothing. The lights would briefly flash off but isnt cycling down again.
    Am i missing something?
    When you create a new trigger to do something different next time the button is pressed, you should cancel the old one unless you want both trigger files to be run.
  • @dc42 Oh how do you cancel the old one?
    I had assuming the new trigger declaration would over write the old one...
    @mangy_dog said in Can you set external triggers to toggle gcode?:
    Read the documentation for M581 on the GCodes wiki page.
  • I have read the docs and maybe I'm blind I can't see anything about canceling the previous trigger?
  • use S-1 to disable a trigger file
  • Thanks
    s-1 wasnt listed on the doku gcode wiki... the reprap gcode wiki did mention it but as a delete all triggers option...
    Anyway its sorted now thanks 🙂
    Thanks
    From the doku wiki:
    Using S-1 with no X Y Z or E parameters sets the trigger back to ignoring all inputs.
