    Solved read travel speed and change it for a while
    • c310
      c310 last edited by c310
      Good evening!
      for printing very small parts i need to
      1. add pause between each layer
      2. move head away from the model
      i made a macro and added to slicer (s3d) M98 Pdwell , so it all works fine
      but i want to change travel speed for this "dwell parking move", otherwise it is very slow and i do not want to change print speed.
      please advise how i can temporary change travel speed and reverse it back after dwell. thanks! 🙂
      this is dwell parking macro
      ; layer change pause for small parts
      G60 S0			; save coordinates to slot 0
      G91
      G1 Z30			; lift 30 mm
      G90
      G1 X75 Y75 		; go away
      G4 S3 			; dwell 5 sec
      G1 R0 X0 Y0 Z30		; return to pause to coordinates from slot 0   Z+30
      G1 R0 X0 Y0 Z0		; return to pause to coordinates from slot 0   000
        You can just add F parameters to the G1 commands in that macro. The original feed rate will be restored automatically when the macro finishes.
        • c310
          c310 last edited by
          thank you a lot!
