    Having trouble setting up bulldog clip offset for homeall
    • 3dprinting meathead
      3dprinting meathead last edited by
      so, I got a new piece of glass, and tried to set up an offset for the clips, and now my home z doesn't offset at all. I'm sure I messed up something, but not sure what.
      Here's
      ; bed.g
      ; called to perform automatic bed compensation via G29
      ; generated by RepRapFirmware Configuration Tool on Sat Feb 18 2017 23:41:13 GMT-0500 (Eastern Standard Time)
      ; Clear any bed transform
      M561
      ; Home all axes
      G28
      ; mesh bed leveling
      M557 X40:155 Y0:195 S80
      and here's
      ; Configuration file for Duet WiFi (firmware version 1.17)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X40 Y0 Z0 S1 ; Set axis minima
      M208 X155 Y200 Z260 S0 ; Set axis maxima
      and here's
      ; homez.g
      ; called to home the Z axis
      ; Lift Z relatively to current position
      G91
      G1 Z5 F8000
      ; Back to absolute positioning
      G90
      ; Go to first bed probe point and home the Z axis
      G1 X40 Y0 F8000
      M280 P3 S10 I1
      G30
      M280 P3 S90 I1
      G91
      G1 Z5 F100
      G90
      any input is appreciated
      If I can learn it, than anyone can learn it.
        ok, I think I got it figured out
        Old
        New
        M208 X-40 Y0 Z0 S1 ; Set axis minima
