    Over extrusion with small segment and/or bad retract, need help !
    • Hugues
      Hugues last edited by
      I've 2 problem now with my setup (core XY), maybe you can help me to figure out what's happen…
      1 - Hi-res file seem over extruded, i mean long sequence of short segment are over extruded as this picture show :
      It's the baby groot file from thingiverse, body contain lot of segment and the head was supported by a low poly cylinder. There were printed on same plate, and my bed was well levelled. I've to down my extrusion flow to 70 % when they are printing separately.
      2 - Retraction after layer give me a big blob when printing kind of hi-res print, with same setup in S3D, lowpoly file are perfect.
      This is an example of what i get (head zone) :
      I played with retract speed, length, pressure advance, E acceleration…. And i'm lost !
      Files are sliced with S3D.
      Thanks !
      • Hugues
        I find the faulty guy… simply3d ! I spend an half day to figure out what's happen and slir3r did the job perfectly...
