    Double check code for large format please
    • Supercadadundefined
      Supercadad
      Hi all.
      Please can someone run through my code. I have a duet ethernet and a duex 5. Printer is cartesian style with
      1 X motor
      2 Y motors
      2 Z motors
      BL Touch and a Titan areo extruder.
      I was thinking of using motor stall as end stops but decided against it for now. I would like to have limit switches for both x and y axis at both ends. I have added an 'E-Stop' section for the max limit switches as software should stop the printer going past the designated area.
      Here's my code and thanks in advance
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Apr 02 2019 16:50:15 GMT+0100 (British Summer Time)
      M550 P"Large Format" ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M584 X4 Y3:0 Z1:2 E5 ;Set multiple drives per axis
      M569 P4 S1 ; Drive 2 goes forwards
      M569 P5 S1 ; Drive 3 goes forwards
      M92 X80.00 Y400.00 Z400.00 E436.54 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X800 Y900 Z200 S0 ; Set axis maxima
      M574 X1 Y1 Z2 S1 ; Set endstops controlled by limit switches
      ;E-Stop Conditions
      M581 E4 S1 T0 ;Trigger E-stop if X Max Limit switch reached
      M581 E5 S1 T0 ;Trigger E-stop if Y Max Limit switch reached
      M581 E6 S1 T0 ;Trigger E-stop if Z Max Limit switch reached
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:785 Y15:885 S50 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P3 S0.3 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P4 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P5 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      • Vetiundefined
        Veti
        @supercadad said in Double check code for large format please:
        B4138
        that is most likely not correct for your thermistors as it is the default from the configuration tool.
        Also you might want to add this at the end
        T0 ; Select first tool
        Supercadadundefined 1 Reply Last reply Reply Quote 0
          Supercadad @Veti
          @veti Good spot, thanks
          I have altered my thermistor to suit what I am using.
          What does the T0; Select first tool do?
            Phaedrux Moderator @Supercadad
            It selects a tool so that you have a valid target for setting temperatures etc. You can't print without a tool. Adding T0 to config.g means that a tool will be selected at startup. You can also add T0 to your start.g file. or to the slicer start code. Most slicers will also ensure a tool is selected before they set a temp, but users always seem to find a way to work around that and end up with an error from trying to extrude with no tool selected.
