    Enable endstops on a Duex5
    2812
    • Loffy770
      Loffy770 last edited by
      I have Duet WiFi and a Duex5. Now I have connected Sunex GL 8 endstops to 5v on Duex and it looks to be working ok, they light up so some reaction is in there. But how do I assign them to my XYZ.. cant find any info on that..
      Thanks
      Roger
        Currently there isn't a faciliary to reassign endstop connections. This is on the firmware wish list.
        • Loffy770
          Ohh, can I use the drivers on Duex as XYZ and get around the problem in that way?
          • Loffy770
            Okay, I have pulled 5v from Duex5 and moved the signal to Duet, it lights up but there is no reaction when doing a home… The way I tested it was by doing a safe distance Z home and then putting a screw driver on the sensor. It lights up but does not stop the Z from moving...
            Am I missing something?
            • iDevelo
              iDevelo last edited by
              @Loffy770:
              What commands are you using to home Z?
              • Loffy770
                Just the home buttons on the web interface and or Paneldue.
                  @Loffy770:
                  Sorry, mapping drivers does not map endstops.
                  • Loffy770
                    So how can I get past this.. whats the workaround?
                      @Loffy770:
                      Use M119 or the Settings->Machine Properties tab of DWC to test the endstops.
                      Can you post a link to the datasheet of the endstops, and tell us how you have connected them to the Duet? Does the endstop LEDs on the Duet show the correct endstop state?
                      • Loffy770
                        I took voltage from Duex endstop + & - then I took signal from Duet endstop Z.
                        When Z is moving I get a led from Sunx when I put a screwdriver on it on Duet Zendstop the led comes on with red light. Z continues to move though.
                        Sunx link http://www.clrwtr.com/PDF/SUNX/SUNX-GL-8U-Proximity-Sensors.pdf
                        With m119 I get a popup
                        Endstops - X at min stop. Y at min stop. Z at min stop. Z probe not stopped.
                        • Loffy770
                          These end stops are rated 12-24 but works with 5v as they are originals in my printer and runs well with 5 v.
                          • Loffy770
                            any ideas? Some more to test?
                              Which particular model of the GL8 series are they?
                              • Loffy770
                                Its a Gl8h top sensing 3 wire model "normally open"
                                  Have you set up your M574 command and your homez.g and homeall.g files to tell the firmware that you are using an endstop for Z homing? See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer. Your files may be set up for Z homing using a Z probe instead, depending on where they came from.
                                  • Loffy770
                                    Well I used the configurator to set it but I will go through it again.
                                    Just to be on the safe side.. I connected black signal cable to the outer pin closest to usb port on Duet. Looking at schematics for Duet it looks like it should be the other way around.. but if I do that I get no led light on Duet.
                                    On Duet I have + brown cable and - blue cable.
                                    • Loffy770
                                      Can confirm the wrong in the schematics now, just measured it and power is wrong in the Duet schematic.
                                      • Loffy770
                                        I have M574 X1 Y1 Z1 S0
                                        Had a M558 line active and put a rem in the front now, is that correct to rem that line and use the above for open and low homing?
                                        If so I will test this now.
                                        • Loffy770
                                          Configuration file for Duet WiFi (firmware version 1.17)
                                          ; generated by RepRapFirmware Configuration Tool on Sat Mar 04 2017 15:46:00 GMT+0100 (W. Europe Standard Time)
                                          M111 S0 ; Debugging off
                                          G21 ; Work in millimetres
                                          M208 X370 Y250 Z280 S0 ; Set axis maxima
                                          M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
                                          ;M558 P1 X1 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                          G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                          M557 X15:215 Y15:195 S20 ; Define mesh grid
                                          M92 X80 Y81 Z390 E189 ; Set steps per mm
                                          M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                                          M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                                          M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M143 S285 ; Set maximum heater temperature to 260C
                                          M305 P0 T130600 B6084 C2.635903e-7 R4700 ; Set thermistor + ADC parameters for heater 0
                                          M307 H0 P130.1, I0.213, D449.1
                                          M563 P0 D0 H1 ; Define tool 0
                                          M550 Black Widow ; Set machine name
                                          M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                                          • Loffy770
                                            Okay I have X homing as it should!
                                            Y is homing in the wrong direction even though I did set it to low. Tried o change it to high incase there was a bug or something but it didnt work… It however stops if I put a screwdriver on the sensor so the sensor is communicating to the board correctly.. Its just the motor homing in the wrong direction despite being configurated as below.
                                            ;M558 P2 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
                                            ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                            ;M557 X15:355 Y15:235 S20 ; Define mesh grid
                                            Z does not stop with any metal on it but it still lights up on the board.
                                            Firmware Name: RepRapFirmware for Duet WiFi
                                            Firmware Electronics: Duet WiFi 1.0 + DueX5
                                            Firmware Version: 1.17c (2017-01-14)
                                            WiFi Server Version: 1.03 (ch fork)
                                            Web Interface Version: 1.14a
                                            • Loffy770
                                              Updated to 1.17e with no differance on homing
                                              • Loffy770
                                                Y homing sorted out… works.
                                                Now trying to fix Z
                                                • Loffy770
                                                  I would like to see how a Homez.g for a carthesian without probe looks like… Mine has a probe setting. Can anyone post one?
                                                  • jacksat
                                                    jacksat last edited by
                                                    Did you read these yet
                                                    https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_files
                                                    If you home Z using a microswitch instead, then you can use a pattern similar to homex,g and homey.g. However, if you use a low-end homing switch that triggers a little before Z=0, then you can't use M208 to define the homing position, because it would prevent you moving below the trigger height. You can use a G92 command after homing instead. Here is an example, for the case where you have a low-end homing switch that triggers at Z=0.3mm:
                                                    G91 ; relative mode
                                                    G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
                                                    G90 ; back to absolute mode
                                                    G1 X0 Y0 F2000 ; put head wherever you want it to be when you home Z (omit this line if it doesn't matter)
                                                    G91 ; relative mode
                                                    G1 Z-200 S1 F100 ; move Z down until the switch triggers
                                                    G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
                                                    • Loffy770
                                                      Seems like the configurator is putting out the wrong content, it does put out probe in homez even if probe was deselected.
                                                      Will read that link thanks, have a homez based on Y content now as a start and it works…
                                                      Just trying to understand how the files are built up and relates.
