    M592 seems to have no effect on extrusion (in machine control)
    • dgrat
      dgrat last edited by
      M592 seems to have no effect if I test extrusion from the "Machine Control" tab.
      If the following statement is true, I don't really know how to test it, because theoretically G1 E* will not work too?!
      Nonlinear extrusion is not applied to extruder-only movements such as retractions and filament loading.
        dc42 administrators @dgrat last edited by
        Nonlinear extrusion is only applied to printing moves, i.e. moves that involve both XY movement and extrusion.
        • dgrat
          is there a way to test this without xy movement?
            dc42 administrators @dgrat last edited by dc42
            @dgrat said in M592 seems to have no effect on extrusion (in machine control):
            No. If we applied nonlinear extrusion to extruder moves with no XY movement, it would mess up retraction distances and filament loading.
            You can test M592 by doing a slow X and/or Y movement + extrusion, with the nozzle well clear of the bed. For example, if you do G1 X0 followed by G1 X100 E100 F300 then both X and E will move 100mm at 5mm/sec.
            • Keith53
              Keith53 last edited by
              I been playing with M592 and did not get what I was expecting but think it should work. I will test print tomorrow and let you know if it helps.
              I made the program below to move XY and E and measured how much filament is pulled. I ran it without M592 to get the numbers for the spread sheet. I have used the spread sheet found in other threads and came up with M592 A.018 B-.0015. My printer is a ANET A8. I left the default steps/mm at E100 for the tests and turned presaure advance off.
              PROGRAM:
              M104 S240 ; set temperature
              M98 P"homeall.g"
              G1 Z25.0 F1500 ;Move the platform down 25mm
              G1 X10 Y10 F1500
              M204 S760 ;Acceleration
              M572 D0 S0.0 ;Preasure Advance
              M592 D0 A.0183 B-.0015
              M109 S240 ; set temperature and wait for it to be reached
              G21 ; set units to millimeters
              G90 ; use absolute coordinates
              M82 ; use absolute distances for extrusion
              G92 E0
              ;1mm/s=60MM/MIN
              ;2mm/s=120MM/MIN
              ;3mm/s=180MM/MIN
              ;4mm/s=240MM/MIN
              ;5mm/s=300MM/MIN
              G1 X110 Y110 E90 F300
              M104 S0 ;extruder heater off
              M98 P"homex.g"
              M84 ;steppers off
              With M592 D0 A.0183 B-.0015 I get the following:
              1mm/s = 94mm pulled
              2mm/s = 93.5mm pulled
              3mm/s =93.5mm pulled
              4mm/s =93.5mm pulled
              5mm/s =93.5mm pulled
              I expected M592 to get all feed rates closer to 90mm pulled. Any ideas why it did not do what I expected? I know I can change the steps per mm for E. Couldn't a formula be such that A and B would put the calibration to 90mm?
              • deckingman
                deckingman @Keith53 last edited by
                @Keith53 Non linear extrusion is to compensate for extruder slippage. So it can only increase the extrusion amount. You should calibrate the extruder steps per mm to give the correct feed rate at low speed.
                • Keith53
                  Ok that makes sense. I was wondering why this was in the spread sheet and now I know.
                  Thanks
