    How many temperature sensors on Duet
    • pabomanundefined
      paboman
      What is the maximum number of temperature sensor Duet can manage?
      I would like to add controlled hot chamber but I already have 2 hotends and 1 bed, no more temp inputs.
      Are there some pins to addres to read one more temp sensor ?
      thx!
      1riundefined 1 Reply Last reply Reply Quote 0
      • 1riundefined
        1ri @paboman
        @paboman
        This may help you
        https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
        See the xpansion pinout. 35 to 39 are what you are looking for, I think
        pabomanundefined 1 Reply Last reply Reply Quote 1
          The maximum number of temperature sensors supported in firmware is 16. That's 8 thermistors or PT100 sensors, and 8 PT100 or thermocouple sensors connected using daughter boards.
          • pabomanundefined
            paboman @1ri
            so without the daugher board I can connect an NTC probe directly to pin 35 (thermistor) and pin 40 (vssa) right ?
              You must also connect a resistor (usually 4.7k) between the thermistor input and VREF on the expansion connector.
