    Any update on when DWC login authentication may be available
    • Crash69
      Crash69 last edited by
      I know its likely a significant change to enable.. but any update on when login authentication to DWC might be coming?
      I have seen discussion around needing to be the highest grade.. but I would be happy with anything.. right now if I open up my router there is no security at all, not even a login prompt to try to dissaude the most basic of users from playing with my printer.. I'd be happy with a simple login authentication prompt, no login no access or preferably view only - even it is done at the lowest standard of security it will be a lot better than none at all!
      Thanks
      • 3dprinting meathead
        3dprinting meathead last edited by
        I have a password on mine.
        Maybe not the most secure system, but it does have a login.
        https://configurator.reprapfirmware.org/
        here's the configurator, shows the option to name and enable a password
        If I can learn it, than anyone can learn it.
          If you change the password from the default using M551, you will get a login prompt in DWC.
          • Crash69
            Thanks guys!
            Yup that at least gives me some confidence I can open the port on my router and monitor prints while I'm at work.
            I didn't realise that password would stop DWC from connecting, I think when I was setting up the wiki examples mentioned "currently not in use" so ignored the password setting at the time.
            Is there any update on when a more detailed login control may be implemented in DWC? nothing crazy I'm just thinking fairly basic view only vs ability to stop/start/manage printer.
            Thanks again
            • kraegar
              kraegar last edited by
              Perfect timing on this - I thought you couldn't password protect it… wasn't sure what I was going to do for MRRF this year. Putting my printer on with no password would be a bad plan.
              Co-Creator of the RailcoreII CoreXY printer
              https://www.thingiverse.com/thing:2407174
