    Failed to add SSID to remembered list
    • Papsiundefined
      Papsi
      Whats wrong here ?
      M552
      WiFi module is changing mode<LF>
      ok<LF>
      WiFi reported error: no known networks found<LF>
      WiFi module is idle<LF>
      M587 S"FRITZ!Box Fon WLAN 7390" P"1202678137040714"
      M587: Failed to add SSID to remembered list<LF>
      ok<LF>
      Error retrieving WiFi status message: bad reply format version<LF>
      • SupraGuyundefined
        SupraGuy
        M587
        With no parameters will list all of the remembered networks. There is a limit to the number that the module will remember.
        M588 can be used to forget networks.
        M88 S"*"
        This will forget all of the networks that it has remembered so far.
        M88 S"FRITZ!Box Fon WLAN 7390"
        Will specifically forget the one that you were trying to add, in case it was already in there.
        Also see the notes in the wiki here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
        You have to take the wifi module out of reset first, so the M552 S0 command should precede this.
        Lead screw driven printer, powered by Duet 2 Wifi
        MPCNC powered by Duet 2 Wifi
        CoreXY printer driven by Duet 3 6HC
        LowRider CNC powered by Duet 2 Wifi
        • Papsiundefined
          Papsi
          now it works.
          M552 S0 and then M588 S"*"
