    Piezo Plate as tool offset adjuster
    • kuhnikuehnast
      kuhnikuehnast last edited by
      Hi there,
      As I am at odds with changing nozzles due to the process of "re-adjustment" of the tool offset I got an idea:
      What about using a piezo disc that is laying on the bed to adjust the nozzle offset? The Idea would be:
      1. Probe the height with the typical sensor above the piezo disc (piezo disc not in use)
      2. move the nozzle over the pizeo disc and "probe"
      3. the difference between 1 and 2 is the tool offset.
      This could be implemented as an G-Code like "probe 5 times, take the median" and you could always adjust the offset before every print. (maybe the piezo disc could be mounted on the side or so)
      I think this would be a cool idea especially if you use a tool changer with a fixed probe on the x-carriage like e3d does...?
      What are your thoughts about?
      greetings kuhni
        This is already implemented, as G30 S-2. it works like plain G30 except that when the probe triggers, it adjusts the tool Z offset so that the height at which ot stopped matches the trigger height of the probe.
