    Using Slic3r with Tool Changer
    • St Tawundefined
      St Taw
      I am developing my Tool Changer like E3D machine.
      Using Slic3r PE.
      Trying to print only with tool T3
      The Slic3r creates...
      M107
      M190 S65 ; set bed temperature and wait for it to be reached
      M104 S200 T3 ; set temperature
      At this point T3 is not selected as the operational tool
      My start code...
      G28 ; home all axes
      G1 Z15 F5000 ; lift nozzle
      Then Slic3r puts in
      M109 S200 T3 ; set temperature and wait for it to be reached
      T3 is now selected as the operational tool.
      However no T3 macros have been run to get the tool. So cannot print.
      Any suggestions as the correct way to resolve this?
      Thanks for any help.
        The tool change macros should be run provided that the firmware considers that the machine has been homed when the M109 T3 command is executed, and tool 3 was not already selected. Did the G28 succeed?
        Which firmware version are you running?
        • St Tawundefined
          St Taw
          Thankyou for reply
          I ran the following in console after just powering up machine so not in homed state.
          Here is log
          12:58:22: T: Tool 3 is selected So tool is selected by M109 command but no macro's run.
          12:58:04: M109 S200 T3
          12:57:31: T: No tool is selected
          12:57:23: G1 Z15 F5000 Bed moves OK
          12:57:01: T: No tool is selected
          12:56:40: G28 All homes OK
          12:55:54: T: No tool is selected
          12:55:47: M104 S200 T3
          12:55:14: T: No tool is selected
          12:54:53: M190 S40
          12:54:32: M107
          12:54:01: Message Log cleared!
          Firmware details.
          Firmware Electronics: Duet WiFi 1.02 or later + DueX5
          WiFi Server Version: 1.22
          Web Interface Version: 1.22.6
            If you send T3 instead of sending the M109 T3 command, do the tool change macros run?
            • St Tawundefined
              St Taw
              Repeated the previous sequence exactly the same except replaced
              M109 S200 T3
              with
              T3
              Yes the macros run and it gets the tool.
              • St Tawundefined
                St Taw
                The documentation for M109 says if the T command is used the tool is selected (slic3r behaviour). By implication although not explicitly stated I would expect the pre and post macros to be run.
                So is the a bug?
                Also when I cancel a print no macros are not run to deselect the tool and yet the status is then no tools selected.
                I have in cancel.g
                M0
                T-1
                And yet the macros are not run.
