    "attempting to extrude with no tool selected" while simulating?
    • frank26080115undefined
      frank26080115
      this is kind of annoying
      simply clicked simulate on one gcode file
      the simulation is still happening though, I can see the numbers change, but the errors never stop coming
      edit: I don't think it is ever going to finish
        You can cancel the simulation by pressing Pause Print and then Cancel.
        The message is telling you that you didn't select a tool before running the simulation, and the GCode file doesn;t select a tool. The same thing will happen if you print the file for real, if you don't select a tool first. If you have only one tool then you can work around it by creating a start/g file in /sys and putting a T0 command in it.
          frank26080115
          I know I didn't select a tool, I just think this is a bad user experience, just a big nono in UI/UX design to flood the screen with identical error messages
