    Possibly damaged board?
    731
    • 3D_lowundefined
      3D_low
      I've had my employe install the duet wifi with a duex2. Duet was previously working.
      Problem i'm getting right now is i need to plug the Duet with USB in order to get 3.3v and 5v. I've checked fuse on it and unplugged everything to see if i had a possible short and no luck.
      If i power up the Duet strictly on 12V from PSU i don't get the red/green less to light up. If i plug USB i get a normal behaviour.
      Any ideas?
        1. Is the INT_5V_EN jumper fitted on the Duet?
        2. Is there any sjgn of damage to the small square chip labelled U3?
        • 3D_lowundefined
          3D_low
          David,
          There is a jumper on the INT_5.
          The small U3 chip appears to have a small "bump" on it. I'd say it does looks lightly damaged
          • 3D_lowundefined
            3D_low
              I agree, it looks damaged. If it's a genuine Duet, that's covered by the warranty, so ask your supplier to repair or replace the Duet.
              • 3D_lowundefined
                3D_low
                David,
                It is a genuine one. However, clearly my employee screwed something up while installing the thing. I wonder what he did...
                  dc42 administrators @3D_low
                  @3d_low said in Possibly damaged board?:
                  David,
                  He didn't necessarily screw up. Is it a Duet 1.04, and are you using 24V power?
                  • 3D_lowundefined
                    3D_low
                    12V power, 1.04.
                    Like i said, the board was working fine until the DueX was added. I've looked over the job when i was programming the Duex2 outputs and saw various corners rounded, damaged connectors and wires improperly crimped which leads me to believe it's a screw up.
                    Can I just run it off USB power for the moment until I get it fixed?
                      Yes you can use USB to provide the 5V power. I suggest you remove the jumper on INT 5V EN.
                      • 3D_lowundefined
                        3D_low
                        Thanks David for the answers.
                        Getting an answer for a problem like this on a Sunday... Guess this is why i'm at my 5th board from you guys 😉 Much appreciated
