    PanelDue continuously show WiFi not found error if WiFi missing
    PanelDue
    • frank26080115undefined
      frank26080115
      demonstration video: https://gfycat.com/WeeklyDifferentHellbender
      simply moved the printer to a new building, so none of the old WiFi networks were available
      PanelDue version 1.22.1, I know it's caused by
      If the printer sends a non-trivial response to the PanelDue and the Control or Print screen is being displayed, the response appears in a popup window. The popup times out after 5 seconds or can be closed manually.
      introduced in v1.22, I see the same message being repeated on the USB connection
      RRF v2.02 if you were wondering
      Please consider a better way of handling this
        Yeah that's annoying. You can make it stop in the meantime by sending M552 S0 to set the wifi module to idle.
        I think better customization of the popup windows is coming in the next paneldue firmware release.
          frank26080115
          I think the best course of action is to have RRF only output one message, and subsequent identical messages are suppressed.
          This should be a rule of thumb for any system that can possibly generate messages from a function that have automatic retries.
