    Pressed the Erase Button - not booting
    Firmware installation
    2103
    • interwebsdesigner
      interwebsdesigner last edited by
      Pressed the Erase Button. I have been using a mac with the board until I pressed the erase button by accident. I am using windows 10 on bootcamp and can't get SAMBA to work. Can I use Arduino or a different app to connect to the board?
        Currently the only program I know of that can upload to the Duet WiFi is SAM-BA. I tried the new version of bossac a few days ago but unfortunately it doesn't recognise the SAM4E.
        Is the "Bossa port" visible in the USB port list?
        • Cabbage Mister
          Cabbage Mister last edited by
          @dc42:
          kinda did the same thing with 7 in panel cause I was curious what it does, didn't know it would actual delete the whole file.
          can you provide me a link of SAM-BA
          Thanks,
          Master Cabbage
          May the all-powerful Cabbage be with you
          • interwebsdesigner
            @dc42:
            It is finding the correct port on the mac, but when I try to flash it, it says it couldn't be found.
            As far as SAM-BA, I installed it on bootcamp / windows 10. Arduino IS finding the port and I used that port to try to connect to the board via the gui with no luck. I am at my wits end on this. I cannot get a copy of win7 to access via vmware.
            A friend suggested that the board might have direct access to the chip and could potentially directly burn it with an atmel bootloader?
              SAM-BA does work under Windows 10. Does Windows 10 under boot camp show the Bossa Port in Device Manager?
              • interwebsdesigner
                Yes, Showing up as COM4 (Bossa Program Port). When I try connecting through the GUI I am getting "Error h_handle returned zero". FYI I am using sam-ba 2.16
                • interwebsdesigner
                  Update: I think I got it to work. I thought the board was auto-discovered but it was not. Sam-ba returned SET so I am guessing that is the confirmation?
                  I pressed the reset button also, but now I can't connect to the board from rep host. I feel like I missed a step. Any idea why it is not getting picked up by USB, after flashing / resetting? Also, it is not showing up in the devices under usb.
                    Did you follow the full procedure listed at https://duet3d.com/wiki/Updating_main_firmware#Fallback_procedure_.233 ?
                    • interwebsdesigner
                      I followed it. A few times just to make sure that I didn't miss a step etc.
                      After flashing, I moved back to the Mac, and then back again back to bootcamp win10. Both are not seeing the device. I have disconnected it. Re-flashed it. I also checked to make sure the .bin was the correct file as I saw in other threads some were downloading a container file. Seems like I have done everything correctly, hoping that it is just something I am missing and not something wrong with the board!!??
                      • interwebsdesigner
                        One Note "On completion it will invite you to lock the region; press Yes."
                        I never was prompted to do this? Could this potentially be an issue?
                        • interwebsdesigner
                          I did the compare sent file with memory and getting the following error:
                          Sent file & Memory area content (address: 0x400000, size: 265068 bytes) do not match!
                          from the log
                          [[language]]
                          loading history file ... 0 events added
                          SAM-BA console display active (Tcl8.5.9 / Tk8.5.9)
                          (sam-ba_2.16) 1 %
                          (sam-ba_2.16) 1 % compare_file  {Flash} "C:/Users/--/Downloads/DuetWiFiFirmware-1.17e.bin" 0x400000 0
                          -I- Temp file : C:/Users/--/.sam-ba.testCompareFile
                          -I- Compare File : C:/Users/--/Downloads/DuetWiFiFirmware-1.17e.bin with memory at address : 0x400000 , for 265068 byte(s)
                          -I- Read File C:/Users/--/.sam-ba.testCompareFile at address 0x400000
                          GENERIC::ReceiveFile C:/Users/--/.sam-ba.testCompareFile : 0x40B6C bytes from address 0x0
                          -I- 	Reading: 0x10000 bytes at 0x0 (buffer addr : 0x20002128)
                          -I- 	Reading: 0x10000 bytes at 0x10000 (buffer addr : 0x20002128)
                          -I- 	Reading: 0x10000 bytes at 0x20000 (buffer addr : 0x20002128)
                          -I- 	Reading: 0x10000 bytes at 0x30000 (buffer addr : 0x20002128)
                          -I- 	Reading: 0xB6C bytes at 0x40000 (buffer addr : 0x20002128)
                          (sam-ba_2.16) 1 %
                          Any thoughts?
                          • interwebsdesigner
                            UPDATE! Somehow, when I was updating before, I didn't get an output or the sector lock. I went back and clicked on "compare file" I never did it because it said "if desired". The above error kept on coming so I looked up some detail on that. For whatever reason, I clicked on "send file"… it worked. Got the output, reset the board and it just connected to repetier. Was it necessary to click on compare file?
                            • interwebsdesigner
                              Alright, well I seem to have hit a wall. I can connect with Repetier but it is giving me "No start signal - forcing start". It then runs a couple GCODES and then get "communication timeout - reset send buffer block". Not really sure what to do next here. It seams that the firmware is updating. Since I pressed erase, do I have to add any other of the firmwares? The server or anything like that?
                              I did try uploading the firmware and the server .bin directly through sam-ba with no luck.
                              • Qdeathstar
                                Qdeathstar last edited by
                                Hi.
                                I believe i had to run it as administrator and in compatibility mode with windows 7 to get it to work on my machine.
                                • code0100fun
                                  code0100fun last edited by
                                  @Qdeathstar:
                                  Thanks for that tip. This should really be in the docs. I'm not a regular Windows user so I had forgotten about compatibility mode.
