    No manual extrusion here (hot nor cold)??
    • jacksatundefined
      jacksat
      I can home the X,Yand Z ,I can use the load filamet button and the extruders work they spin happy ,but if i want to extrude 100mm to calibrate the extrusion lenght Nada happens no error mesage nothing ,in the Gcode console you can see that code got registerd but no movent of the extruder motors.
      Am i missing something here ,i think this begon after the last update but not 100% sure.
      Here are some specs.
      And config file
      0_1561805379714_cofig.g
      • Vetiundefined
        Veti
        have you tried enabling cold extrusion?
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
        jacksatundefined 1 Reply Last reply Reply Quote 0
        • jacksatundefined
          jacksat @Veti
          @veti said in No manual extrusion here (hot nor cold)??:
          Thanks for replying .
          Yes i did it is in the title , but same thing no movement on the stepper ,no error mesage,no peep or squeak ,nothing ,nada .
          I was recalibrating the extruders as i changed one from a1.8 degree to a 0.9 degree pancake stepper ,but i didn't like it (skipped steps to easy) so went bak to the 1.8 pancake but never did a retest and i left it for a coupple weeks before i found some time to go furter .
          But before i did a calibration i updated to 2.03 and i cant remember if i did other changes that can cause this besides changing the steps to half that of the 0.9.
            deckingman @jacksat
            @jacksat Have you selected a tool before you attempt to extrude? If not, just enter T0 from the console, then try.
            • jacksatundefined
              jacksat @deckingman
              @deckingman said in No manual extrusion here (hot nor cold)??:
              Yes ,i did but same result.
              But i think it is solved now,need to do more testing but too F-ing hot in the shop where the printer lives.
              I did a reinstall of the firmware and then i deselect and select the tool again and now both extruders work when i push extrude 10mm.
              Don't know if the reinstall fixed it or deselect and then select the tool again did.
              Thanks for thinking along .
