Solved Banging head against a brick wall Request Help!
Your X and Y steps/mm are both 160 which implies that you are using 0.9deg motors. Is that correct? Do the axes move by the correct amounts?
Thanks for the reply.
My motors are standard which I presume are 1.8. This is my first time getting in depth with G code. I should also note that the head is moving a lot slower than when it was running Marlin.
@oscar said in Banging head against a brick wall Request Help!:
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1these are incorrect for the ender 3 and 5.
see the ender 3 guide. (ender 5 is basically a more stable ender 3)
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
Thanks, I'll take a look
I followed the guide, thanks. However when I tried a test print, small overhang scale, it immediately started to print in the homing corner and didn't extrude anything. Am I right in thinking that this is possibly to do with the cura settings? As the machine now homes perfectly.
It's up to you whether to make X0 Y0 the centre of the bed (which is what I do) or to make it one corner of the bed. See https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin. You need to configure your slicer (Cura) accordingly. It sounds to me that you have configured X0 Y0 to be one corner of the bed but configured Cura to centre the print on X0 Y0.
You may want to go through the rest of that configuration and commissioning guide for the Ender 3. It also includes a profile for Cura for the Ender 3 which should have everything setup correctly for orientation. I think you might also have a motor direction or homing direction flipped. The guide would help you identify it.
@phaedrux thanks will do
This post is deleted! -
Can you post your full config?
@phaedrux Thanks for the swift reply phaedrux. I'm glad to say that the action of copying my heater config into chat made me realise the figures were wrong, so I popped into config and changed them. It appears to be working fine now, I'm just running a M307.
I am grateful for the help. It's good to know that there is a place for advice, I'm currently suffering from a psychological disorder that makes it hard for me to concentrate for large periods of time and also makes it difficult to problem solve.
So your help is appreciated.
Glad you got it figured out. There's always great support from many people here, so come on back whenever you get stuck.
