    PCB layout not ideal
    Hardware wishlist
    1.4k
      Why do you want to put the side with the SD card and the LEDs at the front? Most people put it at the side or the back.
      • nopheadundefined
        nophead
        Because I don't have access to the back of the machine as it will face the wall in a row of machines.
          dc42 administrators @nophead
          You don't need to access the SD card slot or the reset button or see the LEDs, except for maintenance if something goes wrong that you can't fix over the network.
          zaptaundefined 1 Reply Last reply Reply Quote 2
            A Former User
            Borderline OT, but transparent filament makes for a somewhat okay light guide for LEDs, but dirt cheap plastic TOSLink cables from the far east are better as they have cladding
            • zaptaundefined
              zapta @dc42
              @dc42 said in PCB layout not ideal:
              You don't need to access the SD card slot or the reset button or see the LEDs ...
              This is how I use it. Completely hidden at the back fo the machine and works very well for me. Would be nice to make it to work with flex extender for people that need access for some reason but I don't know what it takes.
              • hayseed_byteundefined
                hayseed_byte
                I built a control panel for similar reasons. If you didn't want to buid a whole panel, it'd be easy to mount a single (normally open) button to the front of the machine. Wire one side to gnd, the other to pin 44 on the expansion header and you have a reset button.
                https://wildbot.me/wildbot
                Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
                  The only time I ever use the reset button is when uploading firmware via USB. Any other time I want to restart, I use the emergency stop button in DWC.
                  • bricorundefined
                    bricor
                    I have a few priters with Duet Wifi boards, I have found that once the boards are configured there is no need to interact directly with them. I have one machine that the board is completly inaccessible,
                      hayseed_byte
                      When I lived in a house with five other people and everyone had cell phones, tablets, laptops, etc I had to reset my duet pretty often to get it to reconnect to the wifi. Haven't had that problem since getting my own place but I can see the need for a hardware reset button.
                      • zaptaundefined
                        zapta @hayseed_byte
                        @hayseed_byte, doesn't the Emergency Etop of the paneldue reset also the wifi? (I always assumed so).
                        wilrikerundefined hayseed_byteundefined 2 Replies Last reply Reply Quote 0
                        • wilrikerundefined
                          wilriker @zapta
                          @zapta said in PCB layout not ideal:
                          Yes, it does. But it only works if you have a PanelDue. 😁
                          Manuel
                          My Tool Collection
                            hayseed_byte @zapta
                            @zapta Yeah. The cost of a panel due was hard to justify. However, as an industrial maintenance technician, I can whip up a control panel out of recycled parts in no time.
