    ANOTHER "No known networks found" error
    Duet Web Control
    3.8k
    • duncan-rtfmundefined
      duncan-rtfm @duncan-rtfm
      @duncan-rtfm ![This is where my hotend heater is plugged in](0_1562053640951_Hotend heater plugged in.jpg image url)
      And this is where its thermister is plugged in. I also tried the plug next to it, just in case.
      The web interface:
      And the error message:
        duncan-rtfm
        Are all Duet boards this finicky?
          A Former User
          Could be a configuration issue; share the relevant part of your config.g file to show how the thermistor for the heater is configured?
            duncan-rtfm
            OK, hang on...
              duncan-rtfm
              M305 P0 T100000 B4138 C0 R4700
              ; Set thermistor + ADC parameters for heater 0
              M143 H0 S120
              ; Set temperature limit for heater 0 to 120C
              M305 P1 X150 T"K"
              ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel
              (terminal block) on the daughterboard. X151 is the right channel.
              M305 P1 T100000 B4138 C0 R4700
              ; Set thermistor + ADC parameters for heater 1
              M143 H1 S345
              ; Set temperature limit for heater 1 to 345C
                duncan-rtfm
                I got this from "Design Prototype Test"
                  A Former User
                  Not my area of expertise, but i notice you have two commands for M305 P1 ... , one which uses the thermocouple daughterboard which you don't have according to the pictures. Try putting a ; in front of M305 P1 X150 T"K" to temporarily disable that line and see if it makes a difference.
                    duncan-rtfm
                    Yep, I noticed that, too, and have commented out the line. No difference - yet...
                      duncan-rtfm
                      AHA! Some progress. I downloaded a bog-standard configuration file from the configurator for the Anet A8 - sure I know it won't be right, but it will be standard. And now the heater says "Standby" That's progress, right? I'm chuffed...
                        duncan-rtfm
                        And we have LIFT-OFF! She gets hot!
                        • whinsundefined
                          whins @Phaedrux
                          @Phaedrux thanks)
