    ANOTHER "No known networks found" error
    Duet Web Control
    3.8k
      dc42 administrators @duncan-rtfm
      @duncan-rtfm said in ANOTHER "No known networks found" error:
      Hi. Yes, T0 is the last line of the RRF Config generated config.g file
      That would be because you checked the "Select first tool on startup" box.
      duncan-rtfmundefined 1 Reply Last reply Reply Quote 0
      • duncan-rtfmundefined
        duncan-rtfm @dc42
        @dc42 Shouldn't I do that?
        I've gone and bought a whole new hotend with heater and thermister already assembled (in case I screwed up that side of things). No difference. I THINK I have the hotend and its thermister plugged in correctly.
        So I'm confused...
          duncan-rtfm @duncan-rtfm
          @duncan-rtfm ![This is where my hotend heater is plugged in](0_1562053640951_Hotend heater plugged in.jpg image url)
          And this is where its thermister is plugged in. I also tried the plug next to it, just in case.
          The web interface:
          And the error message:
            duncan-rtfm
            Are all Duet boards this finicky?
              A Former User
              Could be a configuration issue; share the relevant part of your config.g file to show how the thermistor for the heater is configured?
                duncan-rtfm
                OK, hang on...
                  duncan-rtfm
                  M305 P0 T100000 B4138 C0 R4700
                  ; Set thermistor + ADC parameters for heater 0
                  M143 H0 S120
                  ; Set temperature limit for heater 0 to 120C
                  M305 P1 X150 T"K"
                  ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel
                  (terminal block) on the daughterboard. X151 is the right channel.
                  M305 P1 T100000 B4138 C0 R4700
                  ; Set thermistor + ADC parameters for heater 1
                  M143 H1 S345
                  ; Set temperature limit for heater 1 to 345C
                    duncan-rtfm
                    I got this from "Design Prototype Test"
                      A Former User
                      Not my area of expertise, but i notice you have two commands for M305 P1 ... , one which uses the thermocouple daughterboard which you don't have according to the pictures. Try putting a ; in front of M305 P1 X150 T"K" to temporarily disable that line and see if it makes a difference.
                        duncan-rtfm
                        Yep, I noticed that, too, and have commented out the line. No difference - yet...
                          duncan-rtfm
                          AHA! Some progress. I downloaded a bog-standard configuration file from the configurator for the Anet A8 - sure I know it won't be right, but it will be standard. And now the heater says "Standby" That's progress, right? I'm chuffed...
                            duncan-rtfm
                            And we have LIFT-OFF! She gets hot!
                            • whinsundefined
                              whins @Phaedrux
                              @Phaedrux thanks)
