    SD card contents?
    • cip123undefined
      cip123
      Hi there,
      Trying to get my SD card setup, can anyone provide me with the SD card contents?
      https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents
      I found them here but having trouble finding a way to download the folders
      Cheers
        https://github.com/T3P3/Duet/blob/master/Duet2/SD Card Contents/SD_Card_Contents.zip
        Does the download button at that link work?
        There's no real magic to the SD card though. You can manually create the folders needed: macros, gcodes, sys, www.
        The web configurator can be used to create the config file set suited to your printer. https://configurator.reprapfirmware.org/Start
        This guide has an overview of the process of going through the configurator and getting the SD card prepared. It's for the Ender3, but it should apply more broadly. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
        • cip123undefined
          cip123
          It does but I was hoping there would be a way to download it more in bulk rather than single files.
          I'm new to this and when I had some trouble sorting out passwords I decided (stupidly) just to format the card and start again, but now obviously it's not opening up webcontrol properly.
          I have a guide here - https://learn.ooznest.co.uk/Guide/Connecting+Updating+and+Configuring+Your+WorkBee/19?lang=en
          The config looks good but I get confused quite quickly with it all. I'm very new to this side of 3dprint/cnc
            Understandable.
            I think between the link from workbee and the links I posted above you should have all the tools necessary.
            Feel free to post any other questions or issues you may run into.
            • cip123undefined
              cip123
              Hi, got the SD working however ran in to a few problems.
              Following my workbee guides I started uploading my config.g and it asked to reboot, however when it rebooted it didn't come back online I had to manually bring it back. Is this normal?
              Once I brought it back I continued to upload the next few files, update the firmware and add .bin files. However got this error when trying to upload some files - Could not update file 0:/www/dwc.json!
              Any ideas?
                A Former User @cip123
                @cip123 said in SD card contents?:
                Hard to say without seeing your config file and knowing if is a wifi or ethernet board, etc. Did it connect to your router and obtain a ip address but not enable the web interface? Did it not connect to your wifi? And so on.
                • cip123undefined
                  cip123
                  @bearer said in SD card contents?:
                  Hi, I'm using a duet 3d wifi 32 bit controller. - https://ooznest.co.uk/product/workbee-cnc-full-kit/
                  The one supplied with this kit.
                  Thinking that the www/dwc.json! file could be when I formatted the card however I copied all the www files over when I set it up again.
