    Trigger Height and a lot of confusions
    Smart effector for delta printers
    970
    • Johncoffeeundefined
      Johncoffee
      This post is deleted!
        I assume you're talking about this process?
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
        The response logged in the console when doing G30 S-1 should be correct if you're following those procedures.
        Nielsundefined 1 Reply Last reply Reply Quote 0
        • Nielsundefined
          Niels @Phaedrux
          @phaedrux should it be stopped @ 0?
            Well not necessarily. It should stop at the trigger height.
            For nozzle contact probes that would be at 0 or slightly negative as it presses into the bed a bit. For proves that have a switch of some kind mounted above and to the side of the nozzle it would be some positive value.
            • Nielsundefined
              Niels @Phaedrux
              @phaedrux BUT when i drive to z=0 after g32 i should above the bed?
              That isnt working
              It drives IN the bed 😕
              • Nielsundefined
                Niels
                state:
                M665 R225.5 L450 B185 H410.500
                M558 P8 R0.4 H5 F1200 T6000
                G31 P100 X0 Y0 Z0
                Nozzle 210°
                Bed 60°
                • Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                  -> Done. works. Bed stopped after g30
                • Use the X and Y jog buttons to position the nozzle over the centre of the bed
                  -> Done x0 Y0
                • Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                  -> paper scratched @ Z 1.84
                • Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                  -> Done ... Z=0
                • Jog the head up by 5 to 10mm
                  -> Done M120
                  G91
                  G1 Z5 F6000
                  M121
                • Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported.
                  -> G30 S-1
                  Stopped at height -0.029 mm
                  Z=-0.03
                • Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                  -> -0.022 -0.029 -0.022 -0.029
                • In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                  -> G31 P100 X0 Y0 Z-0.025
                  saved
                • Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                  -> done . Only PID tuning Stuff in the override
                • To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                  -> Restarted
                After All:
                • G32 (look at pastebin)
                • After that it stops at Z=5
                • when i drive to Z=0 or start the print ---- the nozzle crashes in the bed.
                G30 S-1 Stopped at height 0.797 mm
                So annoying ... whats my mistake?
                • Nielsundefined
                  Niels
                  After all:
                  When i do a G30 i got the correct height ....
                  Why does the g32 (bed.g) does not this?
                  • Nielsundefined
                    Niels
                    i realized that there are not compensation in use.... this is exactly what the g32 should to right?
                      Phaedrux Moderator @Niels
                      @niels g32 will only run the commands in bed.g
                      Do enable the compensation there must be a g29 S1 at some point to load the saved heightmap or G29 to run a probing cycle.
                      Usually best put in the slicer start gcode. Or at the end of bed.g which ever makes best sense.
                      • Nielsundefined
                        Niels
                        Yes. i know ..
                        in my bed.g i do alot of g30 and the last one with s6.
                        --> fail
                        when i do a single s30.. it sets the height correctly....
                        this is what i didnt understand
                        • Nielsundefined
                          Niels
                            Being that this is on a delta all I can recommend is to recheck your calibration routine. Not my area of expertise unfortunately.
                              Try running G32 twice after power up before you drive to Z=0. If the M665 parameters in config.g are a long way from the true values, then there can still be a height error after running G32 once. This is especially true in firmware 2.03, and there will be a 2.03.1 release to fix this.
