    Random stop when PC is connected
    • wuemundefined
      wuem
      Hello
      Since one week we have a problem with our Duet 2 Ethernet, that we did not notice before.
      Our prints suddenly stop, the bed moves down and the connected PC tells me on the website, that the connection is lost. The behavior of the Duet looks the same, as if I press "emergency stop". As I said, the stop always occurred at random places. The only thing, that seems to be reproducable is, that it only happens, if a pc is connected. When there is no PC connected, it prints to the end.
      Also the log file does not really help:
      Logfile of print, that stopped:
      2019-07-08 12:55:22 Started printing file TopfOverhangTest_0.5mm_schnell_nowand.gcode
      power up + 00:00:00 Event logging started
      power up + 00:00:01 Error: M557: bad grid definition: X range too small
      power up + 00:00:02 Network running, IP address = 169.254.97.197
      power up + 00:18:20 HTTP client 169.254.196.202 login succeeded
      2019-07-08 13:52:52 Date and time set at power up + 00:18:20
      Logfile of successful print:
      2019-07-09 10:56:41 Started printing file TopfOverhangTest_119_steil.gcode
      2019-07-09 12:17:34 Finished printing file TopfOverhangTest_119_steil.gcode, print time was 1h 21m
      Since there is no entry in the logfile, I assume, that there is a system crash.
      Any help available?
      Thank you. Michael
        Next time it happens, don't restart the Duet, instead reconnect (use USB if DWC won't reconnect) and send M122. Look at the Last Reset Reason and the Software Reset Data. the Last Reset Reason will tell you when and why the Duet last started up or restarted. If the restart was caused by software, the Software Reset Data will say why.
        If you haven't done a software reset since the problem last occurred, then the Software Reset Data may still contain useful information if you run M122 now.
        • wuemundefined
          wuem
          Thank you for your quick answer. Unfortunately I think, that the Duet restarts itself. When you look at the logfile it says:
          Does "power up" not mean, that it restarts?
          Anyway. I will try to catch the next shutdown and look, if M122 will help.
          Regards. Michael
          • wuemundefined
            wuem
            And something else: is "a software reset" the same as a restart? Or do I have to do something special for a software reset?
              dc42 administrators @wuem
              @wuem said in Random stop when PC is connected:
              A software reset can be caused by you (because you sent M999 or you pressed the Emergency Stop button), or by the firmware because it detected a serious problem. The "Last software reset reason" in the M122 report says which.
