    Is the current v3-dev branch borked for anyone else?
    Firmware developers
    701
    • gtj0undefined
      gtj0
      Building target: Duet2CombinedFirmware.elf
      Invoking: Cross G++ Linker
      arm-none-eabi-gcc -L"/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E" -L"/usr/src/3d/dc42/workspace/FreeRTOS/SAM4E" -L"/usr/src/3d/dc42/workspace/RRFLibraries/SAM4E_RTOS" -Os --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -T"/usr/src/3d/dc42/workspace/CoreNG/variants/duetNG/linker_scripts/gcc/flash.ld" -Wl,-Map,"/usr/src/3d/dc42/workspace/RepRapFirmware/Duet2_RTOS/Duet2CombinedFirmware.map" -o "Duet2CombinedFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ""  ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o  ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o  ./src/ObjectModel/ObjectModel.o  ./src/Networking/W5500Ethernet/Wiznet/Internet/DHCP/dhcp.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/W5500/w5500.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/WizSpi.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/socketlib.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/wizchip_conf.o  ./src/Networking/W5500Ethernet/W5500Interface.o ./src/Networking/W5500Ethernet/W5500Socket.o  ./src/Networking/ESP8266WiFi/WiFiInterface.o ./src/Networking/ESP8266WiFi/WiFiSocket.o ./src/Networking/ESP8266WiFi/WifiFirmwareUploader.o  ./src/Networking/FirmwareUpdater.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o  ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o  ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o  ./src/Movement/HeightControl/HeightController.o  ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o  ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o  ./src/Libraries/sha1/sha1.o  ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o  ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o  ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/HeaterProtection.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o  ./src/Hardware/DmacManager.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o  ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o  ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/RestorePoint.o ./src/GCodes/Trigger.o  ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o  ./src/Fans/DotStarLed.o ./src/Fans/Fan.o  ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeProgrammer.o  ./src/DuetNG/DueXn.o ./src/DuetNG/Pins_DuetNG.o ./src/DuetNG/SX1509.o  ./src/Display/ST7920/glcd11x14.o ./src/Display/ST7920/glcd7x11.o ./src/Display/ST7920/lcd7920.o  ./src/Display/Display.o ./src/Display/Menu.o ./src/Display/MenuItem.o ./src/Display/RotaryEncoder.o  ./src/CAN/CanInterface.o ./src/CAN/CanSender.o  ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/Tasks.o   -lCoreNG -lFreeRTOS -lRRFLibraries -Wl,--end-group -lm
      arm-none-eabi-gcc: error: : No such file or directory
      make: *** [makefile:75: Duet2CombinedFirmware.elf] Error 1
      It had been compiling fine. CoreNG, FreeRTOS and RRFLibraries are up to date.
      • JoergS5undefined
        JoergS5 @gtj0
        @gtj0 I don't understand your question (maybe because I'm not native english). You mean that you cannot make because it doesn't find the directory? /usr/src/3d/dc42 is dc42's user directory, you must change it to the directory where you have your files. This is set somewhere in the properties of Eclipse, as far as I remember. (My notes tell me the place is Properties - C/C++ Build - GccPath. And there is one setting for Debug and one for Release mode)
        • gtj0undefined
          gtj0
          It's not finding "something" but the error message doesn't say what's missing.
          It looks like it's being tripped up by the empty double quotes at -Wl,--start-group "" and I think that should be "...CoreNG/SAM4E8E/cores/arduino/syscalls.o"
          @dc42 must have changed something in the .cproject file.
          • JoergS5undefined
            JoergS5 @gtj0
            @gtj0 I expect dc42 is changing a lot those days to prepare Duet3, maybe it's best to checkout files of a few days ago.
            • gtj0undefined
              gtj0
              Yeah, he usually leaves things in a compilable state but I think he just missed this one.
              @dc42 I know you're not around for a while but if you happen to check in, the latest v3-dev has
              "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}"
              in the Cross G++ Linker Settings which Eclipse isn't resolving. The old
              "${workspace_loc}/${CoreName}/SAM4E8E/cores/arduino/syscalls.o"
              works fine though.
                There seems to be a bug in Eclipse, because both of those forms should work, and the one currently check in on github works for me. But we have had previous reports that for some users, only the second form works. Unfortunately I think there may also be users for whom only the first form works, which may be why one of my co-workers changed it to the first form recently.
                I will change it back at the next commit.
                • JoergS5undefined
                  JoergS5 @dc42
                  @dc42 could be this unfixed bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=235157 but it's very old. There is a possible workaround at the end.
                  • gtj0undefined
                    gtj0
                    Just for reference, this is the Eclipse version I'm using...
                    Eclipse IDE for C/C++ Developers
                    Version: 2019-06 M2 (4.12.0M2)
                    Build id: 20190509-1623
                      dc42 administrators @JoergS5
                      @joergs5 said in Is the current v3-dev branch borked for anyone else?:
                      Thanks, I'll try that workaround.
