DueUI 1.1.0 is released!
@t3p3tony OK, I've enabled CORS on the google storage bucket so let's see what that does.
Give it a shot when you get a chance. -
@gtj0 said in DueUI 1.0.0 is released!:
Give it a shot when you get a chance.@T3P3Tony Did you ever get a chance to test after I set up the CORS stuff on the storage bucket?
https://github.com/gtjoseph/DueUI/releases/tag/1.1.0
http://dueui.orgUpdate version for Android App
- There are no functional changes to the app itself.
Make reconnecting to the Duet more resilient
- Decrease poll timeouts to ensure timely detection of disconnects.
- Increase number of reconnection attempts before fatal failure.
- Increase time between retry attempts.
- Refresh on successful reconnect.
- Fix connection listener event names.
Added "Reset Fault" and "Tune" to header widget menu.
- You can now reset a heater fault and start tuning on a heater
using the currently set active temperature directly from the
heater widget's drop down. Actually, you always could do this
if you specified your own "state_commands" on a heater widget
but they're there by default now.
Remove references to old 'dueui-' classes
New File List Widget
- The original file grid widget was just plain ugly and not very
easy to use. Although it remains for backwards compatibility,
the new file_list widget looks and works better. See the example
in the dueui_config_default.json file for more info.
Add ability to remove default classes
- If you have a widget that you need to remove a default class from
you can now use "-classname" in any "classes" widget attribute.
For example if you have "button" widget but you don't want it to
look like a button and want to add some other class, you can
say "classes": "-btn someotherclass" to remove the default
bootstrap btn class then add your own.
WARNING: You MAY have to update some of your widget definitions
to keep some custom classes. For instance, if you previously set
"classes": "btn btn-secondary" on a button widget, you may need
to change it to "-btn-primary btn-secondary" to remove the
default "btn-primary" class.
Fix file/macro lists not fully populating
- When there are lots of files in the /macros or /gcodes
directories and the Duet can't allocate enough memory to
return them all in one reply, it returns a "next" parameter
to indicate that the client should make another request
to get the remainder. We were ignoring the "next" parameter
so the lists were short. We now check the "next" parameter
and continue retrieving files until there are no more to
retrieve.
Minor UI tweaks
- Add DueUI version info to log and settings panel.
- Slight refactor of gcode echo to log.
Thanks for this. Attached is a screenshot of my first draft of a single page version for a 22 in monitor. This is the shot from a windows 10 machine that has moved the elements around a bit compared to the active version. (Both in Firefox). The "production" version is running on another PC running Arch Linux with xampp with 2 virtual servers - one for each of my 2 printers.
I have an idea to also have a minimalist version running on the Duet using an Android Tablet as the client. As long as this doesn't overload the Duet as I also will need the DWC running in the background for other functions.
I have included 2 baby stepping sections which I thought to be useful for me. I wrote 2 widgets added to dueui_widgets.js. The stepping widget works (wonderful for a person that knows no javascript) but the widget for displaying the babystep "position" requires your assistance (see next post). ie display "M290 " z output.
The issues:
... The sense endstops widget doesn't work and this is of course critical.
... The Extruder temp control won't turn the heater off.
... I haven't yet worked out how to style the heater widget as the temperatures are very close to the up/down arrows.
... How do I style the console log to have a larger default height?So far I haven't used it other than preliminary testing until the sense endstop is fixed.
A babystep widget that works.
A babystep_position widget (a display of complete ignorance).
0_1562725404394_baystep_position.txt
The json code.
There is an lpc1768 processor port of duet reprap firmware over on the reprap forum.
https://reprap.org/forum/read.php?147,810214,page=1
For some boards they are limited to the old 0.x dwc
Are there any special requirements for interfacing with the board and serving up web pages with this interface compared with dwc 2.0? -
@garis I have the sense endstop working now by modifying the widget and the corresponding lines in the json file and also a separate jog widget for E. So far so good and I can now use it.
@4lathe said in DueUI 1.1.0 is released!:
Are there any special requirements for interfacing with the board and serving up web pages with this interface compared with dwc 2.0?There shouldn't be. We use the same basic commands.
@garis Nice work! Give me another day and I'll respond to your questions. Then I'll get the Baby Step widget merged in.
@gtj0 Where the panel is at the moment.
